- Mar 10, 2020
- Age
- 122
- 2.5 (4 Cylinder)
- Total Lift
- 0
- Total Drop
- 0
- My credo
- Nothing is so difficult it cannot be overcome by brute force and ignorance =8-)
I just did some routine maintenance of my 2001 Ranger trucklet with 4 cyl. 2.5 liter engine and 5 speed manual box, I have about 70 miles in it now and my butt tells me it's running smoother and has less jolt going from off throttle to on throttle .
I recently removed and ever so carefully cleaned the air intake thing (I forget the proper name) using the special $!$ aerosol cleaner .
The truck has about 140,000 miles on it and runs well but the fuel economy has been dropping steadily why I cleaned and changed . it used to get 25 + MPG but now I'm lucky to get 20, often I only get 18 ~ 19 MPG driving the same routes & speeds I always do .
Also new spark plugs .
It seems to me I'm using less foot feed to go the same speeds, I don't know if this is real or my fervid imagination .
I'm betting the next fill up and mileage check will tell but I'd love to hear any comments .
I wonder if I should remove and clean the E.G.R. valve ? . (it looks *very* delicate)
I mostly work on vintage vehicles, the only ones I have with E.G.R. valves are DIESEL powered and only open at 2,500 RPM or more and when under load, cleaning the valve on those always increases power and fuel economy .
Please chime in and give your honest thoughts .
I don't know if I mentioned I'm a Geezer and hope this will be my very last truck before I die ~ it's a total stripper, basic like I think work trucks oughta be .
TIA,
TIA,
