Leggismaximus ... Did you see the 'edit' button down on the right hand side of your posts? Instead of adding one-line posts, you can just edit the previous post, actually, for some hours, I believe. That cuts back on the 'growth' of post count, and makes things easier to follow without paging and scrolling unnecessarily.
That said, take a look at the other post(you really don't need to make more than one, see first bit above) for commentary.
I would suggest you can use a higher viscosity base oil than the factory recommendation when your mileage gets high. What is high? Dunno. But 200,000 miles gives you freedom to use whatever you want. My old truck never saw 5W20 or 5W-anything as it was designed for the 10Wxx series of lubes. Doubt you could find 5Wxx anywhere back then. With a 10 base instead of a 5, you should start out with a more viscous oil, it will be 'thicker' when cold, and should lessen the taptaptap as the pressure will be a bit higher. Not a lot, but some. If there is wear on the connecting rod and main bearings(cam bearings, also), which there IS, the oil pressure is lower than factory, and that may cause the noises, along with some possible leakage internal to the lifter supports. In most cases, the noise is a long-term wear item, repeat, long term, with no appreciable effect. I have intermittent tapping on startup. It all depends on which lifter/support was under valve spring tension at the time of shutdown last. One or more may leak down when pressured over time, the time being longer than for most owners, and it will leak. It will also tap for a bit on startup. I ignore it. Successfully, so far, with no additional problems. Hydraulics leak, some more than others, and leakage in a lifter is a good thing in my mind, as it means the lifter is NOT getting solidified into one piece by varnish and 'stuff', which can happen if the gizzards never move. Leakage will carry off the stuff that can make the lifter stick. Noise is a good thing in this case.. Funny that.
tom
