Pez
- Feb 23, 2012
- Texarkana, TX
- My credo
- Whoa..
https://www.ebay.com/itm/1998-2001-Ford-Ranger-2-5L-Water-Pump-Coolant-Hose-Inlet-Tube-OEM-F87Z-8290-BB-/191781996690
This pipe F87Z-8920-BB (Dorman PN: 902-004) is the pipe that comes out of the block, bolts to the RH accessory bracket and goes to the lower radiator hose and splits of to feed the heater core.
I have called Ford, O'Reily's, Advanced Auto and Autozone. No one has the ability to find what kind of seal this uses when it goes into the block.
Does it use a o-ring or a sealant? If a oring does anyone know a size or part number?
Thanks for the help.
