i turn the key and hear the fuel pump hum and turn the key to start and just cranks over . this only happens once and a while . turn key off then back on and it fires right up . is this fuel related or ignition switch related?
just had it smoged would that have came up then?Pull the codes and see if you have any serious ignition codes in the computer.
Not necessarily. If you can get it there, most of the parts stores will scan it for you.just had it smoged would that have came up then?
i had same problem turned out to be weak fuel pump.i had to cycle the key a few timesi turn the key and hear the fuel pump hum and turn the key to start and just cranks over . this only happens once and a while . turn key off then back on and it fires right up . is this fuel related or ignition switch related?
Was your fuel pump weak due to age?i had same problem turned out to be weak fuel pump.i had to cycle the key a few times
