holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
I just went and rebuilt a 2.5 for a friend of mine. It's in a 98 with a 5 speed transmission. He ran through some water with it and hydrolocked the motor, breaking the #2 rod and bending the #3 rod. He drove it home, a total of about 1.5 miles, and then moved it around a bit, totaling about another 1.5 miles. there was no internal damage to the motor other than the bent and broken rods and a couple of cracked valve seats.
Went through and replaced the 2 bent rods with new pistons and rods. Replaced the head with a new one, went and replaced all of the rings and replaced the rod bearings as well. Replaced the head, all gaskets, and did a tuneup as well.
The engine starts and runs fine for about 10 minutes, with no noise, then the engine just surges a few times, starts knocking loudly, seemingly through the valvetrain, and dies, almost like it locked up. Then with no wait at all, you can crank it up and it runs fine for about the same amount of time and dies again, with the same result. It will do this over and over again. Watching the live data on my code reader shows me that the calculated engine load goes from about 35% up to about 51% then it dies, It starts surging at about 49% calculated load. All other sensor values show up as normal, and the computer shows no codes, and the check engine light does not come on.
It almost seems to me like a plugged catalytic converter, I have no firsthand experience with this but it's the only thing that I can think of. The truck has about 170k on the clock
