2.5 4 cyl
My truck is at 153000 just woundering what problems people have ran into around this mileage
make sure the timing belt has been changed, other than that just keep the oil changed and drive it...
the timing belt was changed before I bought it I don't know if it was done right though cause the timing doesn't stay constant it u have a timing light on the crank
it won't stay constant unless you have the spout connector off (if that even has one), the timing is computer controlled and it most likely actively changes at idle to help stabilize the idle speed
