2.3l head with 2 plug need help
Cloverj7
gurnee, il
I have a 93 2.3l with the 2 spark plug per cyl now i want to change that to a single plug and suggestions? anything will help. thanks. :shok:
are you asking what head will physically bolt on? Are you looking for more performance or why do you want to go with a single plug head?
if you simply don't want the 4 extra plugs, that's easy to get around... changing to a 4 plug head involves changing intake manifolds also if that's what you're going for...
i want to change it to just a single plug head, do away with the dual plug deal not switch the wires to make them fire at the same time.
simple, just cut off the connector for the drivers side coil pack, ground the outer two wires and cap off the center wire. If you have a factory tach it probably won't work afterward (mine doesn't after I did this) but am working on a plan around that.
