Shumatesoldier6
So I have a 1990 Ford Ranger 4 X2. With the 2.3 it had a miss somewhere and was hard to start sometimes and would not go above 60 mph. Every time I would shift into 5th gear it would stumble lose power and I would have to downshift back to 4th. It was originally diagnosed as a weak fuel pump because it was hard to start sometimes and will take a few cranks so I unhook the battery check out the relay and replaced the fuel pump. After I hooked everything back up I would turn the key on hear the fuel pump and try to start it. it would start but sometimes it would take turning the key on a few times, so basically priming the engine then it would run but once it burn the fuel off that ran into the the injectors it would die. So all of my problems happened after I replace the fuel pump I replaced the timing belt, the timing belt tensioner, the crankshaft position sensor, idle air control valve, throttle position sensor, coolant temp sensor, air intake temperature sensor, all new gaskets on the intake, new plugs and wires and new coil packs , also swapped out the ICM and all the relays were replaced. Eventually after messing with it for so long I could get it to start, it would run terrible and I could not put my foot on the gas, so I ran the codes and I got 21 and 24 which is coolant temp sensor out of range, and air intake temperature sensor out of range. Immediately test for voltage at both both sensors and I got 4.6 volts DC which is normal from what I have read. I have redone the timing twice now and from what I understand there is no adjustment for the 2.3 l all my pulleys we're aligned in the correct position. I thought to myself maybe there's a bad ground somewhere and it's not getting the right resistance or voltage at this point I have no idea so I took off the harness and inspected it thoroughly I found a few wires that were broken off. Mainly a ground that went to the crankshaft position sensor and where the heat shrink tied and several grounds. I also inspected the grounding points and cleaned them. After I repaired the harness I put it back in and nothing has changed the truck wants to start but for some reason it is not starting I even pulled out the ECC and inspected it. It did not smell burnt, all the diodes and resistors inside looks brand new and all of the soldering points were intact. I put the computer back in let it sit for a while with the negative battery terminal off, I thought it would reset and those two codes would go away because of the sensors are brand new. I am completely stumps and have no clue what is going on with this Ranger after I put the computer back in I redid the codes and I got a bunch of bogus codes. I got 21, 24, 14, 96 and that's about it I just don't understand that has all new parts and everything was done correctly if anyone has had the similar issue please help and give your input. I can find nothing online about this issue and like I stated before everything happened right after I replace the fuel pump.
