92dangerranger
Hey guys i drive a 92 ranger 2.3 turbo. ( 86 TC setup). The truck is my daily driver and i love it. But if hammer on it real hard it wants to flutter out the exhaust almost like a lot of mini backfires. There is a major lose in power. I know it runs rich because it will after fire from time to time when you go to shift. I posted about the problem a while ago but no luck. Since then i have realized that it only does it bad on cool or cold days....if it's hot out it's not near as bad or as often. The engine does have a over sized cam in it that i got used and i did not know the specs. But if it was the cam timing the air temp should not change the problem. Any help will be appreciated. ( I was thinking VAM or fuel injector....?)
One more thing when i did the swap i never took the time to hook up the check engine light. does any one know what wire in the 86 wiring harness and (about were i would find it) that i need to hook up. because you cant get a reading off of those system unless you complete the secret with a bulb.
