- Aug 7, 2007
- Troll land
- 4.0 V6
- Tire Size
- 42
Well the time has come for an engine swap and I have made my decision. Everyone says small block, but then I would have to change my whole drive train, tranny, doubler, front and rear drive shafts and spare front and rear shafts. As well as the tranny mount and flat belly skid plate. All of witch are custom.
I have thrown the idea around a bit in the past and now I am going to go with a turbo 2.3 lima 4 banger.
Why a 2.3, lighter then a small block, bell housing pattern will bolt to existing tranny ( M50DR1) and high rpm Hp and torque to spin the 38’s in mud. I have gearing for crawl so im not to worred about losing low end torque with the swap.
I have the turbo setup off a running turbo coupe 2.3, turbo, exhaust manifold, upper and lower intake manifold.
Now you know why im doing this so now to the questions. This whole turbo thing is new to me although I fully understand the dynamics of a turbo system.
Can I use a OHC tempo 2.3, will this block mount to my M50DR1?
What clutch disk and pressure plate is needed to bolt the 2.3 to a ranger M5ODR1?
Or do I have to use a turbo coupe 2.3 or a 2.3 from a Ranger?
Will my turbo parts work on any lima OHC 2.3, or do I need to pull some numbers and match the exhaust manifold and intakes to a certain year head?
How much boost can I put to a stock MAP computer with it still running correctly?
Can I use a naturally aspirated wiring harness and a turbo computer, does there need to be pin variations?
With the modifications of forged pistons, head studs what else needs to be done to a naturally aspirated 2.3 to make it hold up to 20 so PSI of boost?
Any help is appreciated. I have searched and can find info but these main details I could not find info on. I need these answers so I can start looking for my 2.3 to build.
Ah, and its going in this, to make more mud fly off the tires.
