94Reborn
- Apr 23, 2012
I am doing a swap on my 94 ranger. It came with the 2.3 dual ignition and a manual trans. I am installed a 93 explorer 4.0 ohv and a 92 ranger manual trans. The wiring between the explorer and ranger are similar but slightly different. I have what I would call the "power distribution" portion of the wiring harness still installed in the truck, including the headlights lights, blinkers, MAF plug, etc, all the way up to the bulkhead connector. There are four plugs that were disconnected for the 2.3 removal, 2 round and 4 big square ones all near the drivers side firewall, all running to the engine. The engine harness that came with the explorer seems to just have 2 round plugs and they are on the other side of the engine. I went to the junkyard and got an engine harness from a 95, if I remember right, ranger with a 4.0 and manual trans. I grabbed the ecu and the engine wiring from this truck. The two large square plugs match right up, the bigger of the two round plugs match up (this one is grey in color), but the smaller round plug doesn't match. I'm not sure what it runs to, but I think it's either for the transmission or the oil pressure sensors. It's a 2 or 3 wire plug, I'd have to get over to the truck to double check. The plug is black on the outside but red plastic on the inside. So I guess my question is, did anyone else run into this problem, and can I just splice these wires in somewhere?
Also, an even more important question, is I don't know where the EDIS module would plug in. The engine harness I grabbed from the 95 ranger doesn't have a plug for it, and the existing power harness on my truck doesn't have it near the radiator where I've read it goes, because on my 2.3 it was mounted to the motor. Do I need to replace the entire "power" harness on my truck with one from a 4.0? Or can I just splice in the EDIS module to my explorer/ranger hodgepodge?
The guy I bought the engine from gave me the power harness and engine harness from the explorer that runs all the way to the big round bulkhead firewall plug, so I could swap the entire thing over. But the idiot cut it all up and it would be quite a challenge to splice it all back together again. And at that point, would the bulkhead connector even match directly to the one in my firewall?
I know this sounds confusing and probably isn't explained the best way possible, but this is my first complete engine swap, so I'm a bit in the dark. I'm decent with electrical work, but this is a bit overwhelming for me. I read the big 4.0 swap article on this site, and read up on how the EDIS and DIS differ and how they function, but I was unable to find anyone explaining how exactly to wire it in. I know this was long winded, sorry about that. But does anybody have some pointers? Thanks.
