2.3L ('83-'97) 2.3 power steering pump bracket
Cadiz,ky
I’m swapping my manual steering to power steering I can’t find an original bracket for the pump and alternator does anyone know where I could get an aftermarket bracket from
Where did you get the pitman arm? I was going to go the other way, and go from power to manual steering. That's when I found out besides the manual steering gear, I needed the pitman arm that goes on the bottom of the box, it is a different size. You also may need the joint that couples the steering column to the box. The only place I could this stuff was off a junkyard truck. So if you need these other pieces, you might as well pickup the bracket as well. The bracket will be a little more difficult since you need the 4 cyl, but I bet you could also use the bracket from a mustang or something else Ford had with the 2.3.
im near Owensboro, I have an 1985 Ranger 4 cylinder. It has ac , ps both . I check tomorrow on engine size . Let me know if you still the stuff .
