eazrider
- Jul 27, 2010
My daughter has a 1997 Ranger with the 2.3 liter, 5 speed. when I first picked up the truck for her, it had 65K miles. I drove it, and thought it was a turd, maybe the timing belt had slipped, etc. I swaped a new belt in, making sure everything was installed correctly...no difference...still a turd. It seems to have more power on first start up, before the engine comes up to temp, when it is running open loop. After it goes closed loop (computer takes over when it is warmed up) it is difficult to pull into traffic without excessive clutch action, sometimes I even turn off the AC to help get going. Runs well at higher RPM, just a turd on the bottom end. Personally, I think the timing needs to be bumped up a bit, but not quite sure how to do that. could I slot the crank sensor and move it around to advance the timing. Is this a common problen with the 2.3L engines.?..Is there someone familiar with these engines that can help..? Are there any chips/computer preconditioners that can "fool" the computer into a more agressive profile..?
Thanks
Thanks
