Pony Boy
- Apr 21, 2009
- Automatic
I have a 1988 Ford Ranger with a 2.3 turbo engine and the original M5OD from the Ranger. Is there any reason to update the transmission to a newer one from say a Ranger with the 2.5? Did Ford ever update the M5OD for use behind the 4 cylinder engines, or is mine pretty much the same as what they used in the late-model 4-cylinder engines? And the bellhousing bolt pattern on the Duratec DOHC 2.3's is different from the old 2.3/2.5 SOHC, correct?
