Countryboy94
- Jul 9, 2013
- Automatic
I have replaced the icm,fuel pump,crank shaft sensor,starter,ignition switch, solenoid,and I can't figure out the problem...the truck will be going good down the road and it will stall. You have to put it in nuetral and turn the key in the off position to reboot the ignition or else it won't start...I'm thinking it is a relay but idk which one or where they are even located...please help...
