- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
starter fluid didnt do anything.......the plugs are wet
Well, that usually indicates that you are not getting spark...so time to test the spark at the coil and the distributor...or the plug itself...
To test you can just pull the plug wire off any one of them and put in a spare plug if you have one...crank the engine and watch for spark...if not then go back to the coil and test that...but you will need a voltmeter...one that reads thousands of volts since you should be cranking through about 30,000 volts or so...can't remember, but don't set the VM too low or you could fry them.
Can't remember...if this is 4 or 8 plug...but check the passenger side regardless since the drive side does not spark on ignition...
