odley2001
- Nov 15, 2007
- Age
- 50
- cincinnati ohio
I'm building a clone of my high school /college ride and 89 range shortbed s with a twin plug 2.3, i had to put in a new fuel pum and the truck had been sitting for quite a while, changed oil check fluids and the truck started up fairly easy, let it run for a few minutes shut it down restarted and let run for about 10 minutes and then it shut it self off, didn't starve for fuel no mechanical or metallic sound in any way, just like turning the key off. went to restart and the started is load, motor turns and it rumbles like it wants to start but doesn't, starter sounds bad but motor doesn't seem tight, radiator and oil levels are fine and no signs of any mixing between the to. any ideas???
thanks
scott
odley2001
thanks
scott
odley2001
