2.3 efi
swampy422
logan ,ohio
would a intake off a 84 2.3 carburated motor fit on a 88 2.3 efi. the intake is two barrel with a holley 2 barrel carb
it should be fine if your ports are round on the intake they'll be smaller then the ports on the head so it should be fine that way. the only thing is the top left hand bolt hole is in a different position but i think the hole is there on the 88 if not it shouldn't be to much of a problem as long as the others are bolted up. i just put my efi intake on an 83-84 carbed 2.3 and thats the only things that were different
