- Jan 29, 2010
- Central Indiana
- Manual
What's the plan for controlling this thing? An actual ecoboost is direct injected which most affordable aftermarket tuners can't handle. I think you said that MS might be able to control direct injection, but I'm not sure.
Boosting a regular duratec gets you around that. Ranger Duratecs are even more simple than the other Duratecs as they have no balance shafts to add weight and parasitic losses and there's no variable cam timing to deal with either.
So, direct injection and variable cam timing are really nice from an OEM standpoint because they let you fine tune things to get the balance you want between power, fuel economy, and emissions. But OEMs also have armies of power train and controls engineers that can spend literal years tweaking as well as massive budgets. From a swap perspective, it seems like DI just makes things more complex and expensive without adding huge benefit. I think a turbo duratec ("DuraBoost"?) would provide something like 90-95% of the performance of an EcoBoost with less work and complication.
