John501
- Jul 16, 2020
- Kansas
- 2.3 (4 Cylinder)
- Tire Size
- 235/75r15
I know there are other threads on this but I have slightly circumstances. My little ranger's 2.3L can build/keep heat this winter. At first I though it was a stuck thermostat and bad sensor, so I replaced both, and I tested the thermostat before hand it came back good and opened at 192 degrees. The new sensor also works correctly since I tested the radiator with a thermal gun. The radiator at idle dropped the coolant over 45 degrees, I took the readings at the inlet and outlet hoses. So I covered half the radiator with cardboard, and it seemed to work great the gauge was almost at the half way point. But that was 50 degree weather, today got to the low 30s and I was driving home when I noticed the gauge barely holding on the the "N" in normal. I got home and check if my cardboard was still there and it is, even with half the cooling of the radiator covered I still can keep heat in the truck. I plan to cover 3/4 of it now and see what happens but I just want to know. Has anyone done something like this and still had the problem? Is there anything else I should do to the truck to help remedy this issue?
Thanks,
John
Thanks,
John
