2 12i mtx jackhammers. price??
dirttrackracer
Law Enforcement
Solid Axle Swap
Bloomsburg, PA
one last time guys. 2 12in mtx jackhammers with a capasitor and 1000 watt infinity amp. good cond not used mutch. proficinaly installed. what shuld i offer i have a aftermarket alpine head unit so im good up front i just want more base
ok are you looking to buy them from some one? cause they wont fit in your truck.
and they dont look pro installed,
or some one should fire there installer
tee you one aim session with me about systems and i can get you a sweet little setup for a low price. pm me when your ready lol
they wont fit in a extra cab??? its more the proficional knows what he's doin but he doesent care how it looks.
pm'ed
ill sell u this box for two 12's "
You want more bass with same setup or new speakers? If with same setup is box ported, if you get a big sturdy ported box it will significantly increase the lower frequencies(deep bass) and bang harder. If you want some badass speakers look these up. Solobaric 12"L7 Kickers or 15"S AND IF YOU REALLY WANT SOME BANGERS CHECKOUT THE SOLO X 5000 WATTS EACH.
English dude:icon_confused:
proficional
= professional
and that box is ported you have to do alot of looking, or get the same subs to fit that box correctly. i'm sure stuff is close but running the numbers for vol port size and length its almost easier to build a new one.
why did you say that 2 12in subs wont fit in my truck?
= professional
box is fine for most subs with a lower bl (under 25) with xmax's in the range of 14-19mm and a FS of 28-35hz.
so most subs that audio shop sell or even bestbuy will sound great in the box. its 4ft^3 @ 35hz. practically universal for many 12's i described.
op you could run a tapped horn with a single ciare 12W.00 :) boner setup for me
o they will fit. you can get 15's to fix. but from the looks of the pics that box is kinda a bad size to just try and sit it in there
o ok i didnt know what you ment by that. if it dont fit ill eather buy or build a box. whats your estimate on how mutch its worth
ummmm no.
best buy on line likes to sell kickers. ever round sub kicker makes doesnt need anything close to 4cuft of air space. and if he wants thoes mtx. they rate at 2cuft
not to mention the box is "tuned" by its port size length and dia. in relationship to the box size
im not a fan of them so any number i would give would be scwed. but look them up on ebay see what the going price for used ones are
not to sound stupid but if they are tuned for 2cuft would that make 4 because of the 2 subs? im learning so if i am asking a dumb question... well answer it so i know
