Shran
Junk Collector
⭐Supporting Member
Truck of Month
Solid Axle Swap
I believe the truck has BOTH. There is a sensor with a vacuum hose and electrical plug on the firewall, directly above the exhaust manifold(but at the top of the firewall). And there is a sensor on the airbox, that is plumbed to the inside of the airbox, and has an electrical connection on it. The one I disconnected before was the one on the airbox that made the engine die. I did try it again the other day(engine was cold this time though), and it sputtered, then picked up idle and kept running. Haven't driven it yet though.
The one with the vacuum hose is a MAP sensor. Disconnecting that one should make it run like shit. There is not a MAF sensor on that truck because it's a speed density system.
I'm not sure what the one on the air box is, unless you mean that it's in the intake right by the throttle butterfly. That one would be the throttle position sensor.
