2.0 ecoboost swap let talk tech!
remington115
15+ Year Member
Ok , I originally I was going to do a 5.0 swap bought a running and driving 1998 explorer yanked the motor out, still need to pull the 8.8 rear end. BTW this is getting swapped to a 1994 2wd ranger. Fast forwarded to now. I've been researching the ecoboost 2.0 swap for price ,ease, gas prices ect...(ohh E85 is cheap) and because of the M5odr1 bolts to it. Lets get into the fab, It looks like there is fitment issues with the vacuum pump and fire wall I've seen some of the hack jobs that was done. I don't want to do this to my cab. Now it looks like you could move the motor up a bit and forward and still have room for electric fans. But id need some motor measurements. But for theory sake lets say there is room to clear the oil pan to the stock cross member or I cut and weld/ box the cross member to clear the pan and make room to clear the vacuum pump, also less cutting of the ducting for the blower motor( I want heat and Air). And listen I know ill have to swap the pan and pick up to the mustang set up, along with the intake manifold and coolant pipes ect... So now we bring the trans forward, this means drive shaft needs to be lengthened and shifter relocated ( get a hurst shifter the bent one or make a shift lever to clear dash and 40/60 bench), NBD. Now I know there is more to this swap BUT what are your thoughts on just getting it mounted this way? Is there any one out there that has done a cleaner swap besides the tech library (looks hack job to me)? any pictures? any better alternator set ups? Prius Power steering? Thoughts?
Can you do a delete on the vacuum pump? Remote mount an electric pump for vacuum needs.
I've considered doing an Ecoboost swap, but haven't looked into the details, and there would be other major alterations as well.
Why not just use a duratec truck?
I know absolutely nothing about this swap. Following along.
I'm confused as you what you are suggesting.
Use a duratec truck as the recepient? If so that would defeat the idea of swapping his truck and he'd still have the clearance issues.
Use a duratec truck engine as the donor? If so that isn't an Ecoboost. Might be the same/similar engine platform, but lot of differences from what I understand.
It's not spelled out in the original post, but isn't the M5OD that bolts to the EcoBoost different from anything you'd find in a 96?
Not that big a deal, just something to consider.
I like the electric vacuum pump idea. OR eliminate the need for vacuum at all. (Hydroboost brakes? Does 93 need vacuum for anything else?)
My understanding is that the 2.0L/2.3L Duratec shares a transmission bolt pattern with the 2.0L EcoBoost. So, he could use the transmission from one of those trucks in his '94.
Sure, but Remington115 mentioned that in his OP:
So, I'm still not understanding that @PetroleumJunkie412 was getting at there.
I have read it is easier/simpler/cheaper to turbo swap a Duratec than it is to Ecoboost swap and you end up with something close to the same thing that fits and works better.
Interestingly, I'm not aware of any 2.3L Duratec turbo builds here.
I found that looking for a 2.0 swap I know of about the time the new Ranger launched, you guys met the Duratec guy in Detroit. I don't remember the 2.0 guy's name and so far the build eludes me.
I found that looking for a 2.0 swap I know of about the time the new Ranger launched, you guys met him in Detroit. I don't remember the 2.0 guy's name and so far the build eludes me.
I remember seeing that one, too. 2wd green-ish truck that had part of the wiper cowl and firewall cut apart.
While I was MIA for a few years I had considered trading the 4.0 2011 for a 2.3 2011 and messing with it and turbo parts. Decided against it after looking over a 2008 2.3 truck in the boneyard. Nothing in that engine bay is convenient IMO.
SOHC isn't much better (read: its a clustered mess in there), but at least the V6 is designed to be longitudinally mounted, unlike the 2.3 duratec.
It does surprise me more have not tried, tho. I think the tuning end holds a lot of people back with the space age stuff. Also, there were not many good tuning options for direct injection engines until the last 5 years or so. Now it's rather free form on whatever you desire.
