1st gen steering shaft
kozak
Solid Axle Swap
British Columbia, Canada
I am wondering if anyone has taken a steering shaft from an Explorer, or a 2nd gen Ranger and used it on a 1st gen Ranger? The first gen Ranger has a different mounting design at the end it connects to the steering wheel shaft, compared to the newer designed shafts.
Only modification to make it fit would be to drill a hole through the steering wheel shaft for the bolt to go through..
Only reason I ask is because I have 2 2nd gen steering shafts in hand, and the 1st gen Rangers are getting harder to find decent parts for here.
1st pic is 2nd gen shaft onto 1st gen steering wheel shaft
2nd pic is the 1st gen steering wheel shaft
3rd/4th pic is what the 1st gen shaft looks like..
use what you need to to get what you want
my current steering setup is ford/dodge/jeep/chevy......:dunno:
i like the aerostar setup cut down to fit cause it has nice dampner and great u joints...
some iterations of other boxes i used...this one is a chevy box
