I don't believe that I have posted any misinformation. About 95% of the
modification that are listed has been personally tested by myself. The
one or two mods which I haven't personally performed are credited to the
contributors.
On my webpages, I discuss increasing the fuel injectors from 14 lb to 17
lb according to the Accel data sheets - I think that they know more than
both you and I together.
On my 2.3l, I did extensive mods to increase the air flow to both the
intake and to the exhaust system compared to the stock 2.3l engine. This
allowed me to increase the fuel injectors to the max of 19 lb and it ran
successfully and there was a measurable performance increase in my real
world testing. I have many emails confirming this mod with comparable
performance increases. On my website, it is clearly noted that "There is
about a 10% increase in hp (10 hp)". NO place do I make claims of
radical hp increases. If you read through the countless pages, you'll
see that time and time again, I state that it is a combination of small
mods that add up. Unfortunately not to big hp gains but at least to
making the truck a fun truck to drive.
I also list a method of calibrating the MAF to the new fuel injectors.
This made a huge difference. On the MAF page, it states to modify a
junkyard MAF and test it there first. If people are dumb enough to throw
in monster injectors, modify their MAF and expect tons of hp from a
normally aspirated 2.3L then that's their problem. More business for
guys like yourself to clean up the mess.
As for the throttle body spacer, I agree with you except that I have
received many emails from 2.3L owners who disagree and state that there
is a performance increase. I can't verify it and on the webpages, I
attribute the content to CK who provided me with the photos and
information. I know that in designing intake manifolds that the size of
the plenum in relation to the runners will change the hp curve. Adding a
throttle body spacer will increase the plenum size and correspondingly
affect when the peak torque and hp arrive. Considering the lethargic
performance of the 2.3L, it may move the curve 100-150 rpm in the right
direction into a more usable rpm range.
I had been modifying my daily driver 2.3L for over 6 years and the
website documents what worked for me. I took my lethargic 2.3L and made
it into a reasonably fast normally aspirated truck which is what Ford
should of released. Not going to win a drag race but it was a fun truck
to drive.
You state that "The 2.3 is limited in air flow by the cylinder head and
nothing else." That is not quite true when you start with a stock
engine/vehicle. There's a number of things that are listed on my website
that will increase air flow up until the point when the air flow becomes
restricted by the cylinder head design. At the end of its life, my 2.3L
had comparable performance to a 2.8L V6.
I am a member of theRangerStation.com and did regularly read it and
contribute for a number of years.
BTW I gave my Ranger to my nephew last year who is putting in a turbo
2.3l.
