Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Super glue? fixes everything.
The better solution is to go to the “live” front axle that late production 2000 got and that was used until 2011. No hubs, front stays locked together all the time. Big gain in strength, small loss of fuel economy. You need the CV shafts and wheel bearings from a live axle truck and to plug off the vacuum system.I am not sure if this will help anyone, but I found a 98 Ranger from California here in Ohio and I rebuilt the entire front end. The only thing I used that wasn't brand new was the front differential axle housing. I replaced all the internals, from the gears all the way out to the manual locking hubs which I was forced to use because I could not find an original set of hubs. Both my hubs came within 100 miles of driving, along with the classic vibration that comes and goes every time you hit a bump. The manual hubs are heavier than the originals and need to be secured somehow. I have found a few solutions were people used glue, silicone, or CV joint metal zip ties.
What I have found, worked best for me was to very carefully bend the plastic tabs up and away from the center of the hub so they lock in stronger. I have seen people apply heat for this but you have to be very careful as it is extremely easy to melt the plastic. Unfortunately I cannot find any better solution, as I fear this will not fix the issue permanently either, only time will tell. Good luck, please let me know if anyone finds a better solution. Thanks all.
