- Nov 16, 2014
- Manual
I have a 1999 Ranger 2.5 4 banger, I finally got it running and went tinkering with it today to recheck fuel pressure.
Initially the truck would not run, I took out the pump and replaced the fuel line that appeared to have popped off the pump. I did notice the truck had no regulator on the line and assumed it may have had the 1998 equipment since it was built in 1998.
Today I got to looking at the fuel rail while doing plugs and wires, I have never seen plugs or wires that utterly destroyed...
I noticed however it does not appear to have a return fuel line, I mistook the EVAP line from the pump cap to the front of the vehicle as a return.
Has anyone seen or heard of someone removing the regulator altogether? The fuel pressure sits steady at 85psi constantly, it does run and drive but bogs when you let out of it suddenly (flooding I assume).
I ordered a Spectra pump assembly with the regulator from Rock Auto, which should be here Tuesday, but I was curious if anyone has seen something like this and what it would do to the truck. I assume they thought the damper on the rail was the regulator?
