1999 Ford ranger---Superlift shocks???
BlueLighting1999
Des Monines,WA
So i was a t my local 4wheelparts looking around and saw a pair of Superlift Shocks that will provide a 4inch lift.... Is this true??
:icon_confused:
no, they are the shocks that come with the 4" superlift lift
no it will not lift your truck at all.
hmm... okay why not?
The springs and torsion bars will just squeeze longer shocks down, if they will fit in there at all.
IM just trying to understand suspension more
The rear suspension has blocks between the springs and the axle. The way you lift the rear is with a taller block or a longer shackle at the rear of the spring. Do not stack lift blocks.
There is no cheap way to lift the front beyond a 1.5" to 2" torsion twist. Mounting points are mounting points and travel is travel.
and also trying to,lift my truck for cheaper.
Body lift.
http://www.therangerstation.com/forums/showthread.php?t=42452
