azrangerman85
I have a flashing OD light and the code says p0715 , " Turbine Input Speed Sensor Circuit "
the only speed sensor I can visually locate is the rear differenetial . I tried diagnosing it , the transmission was shifting hard but it was shifting into all gears , so if I go and shut it off the light flashing turns off , sometimes it doesnt come on at all. I put half a quart of Maxlife Valvolone atf because it has detergent and I wanted to see if the sensor was being thrown off from break in material ( 55,000 miles ) . Once I put the maxlife atf half quart in, the flashing light started to disappear , reappear then disappear then finally disappear for way longer . It flashed today after driving 2 days without it then it turns off again . Is this a filter/ fluid needing changing ? And which sensor is it since Oreillys sold me a speedo sensor i cant even visually locate?? I dont think there is a speedo style sensor on my transmission model any help is wanted. I dont want negative " rebuild" it bullshit . Only serious diagnostics
