rclinton
I removed my factory radio to repair the interior molding. When I reinstalled the radio is was non functional. The lighting works when I turn on the exterior light but the clock/station indication is dead. I trouble shot the wiring harness and found that the ACC power source ( yellow/black) is hot when the key is turn to ACC or the truck is running but there is no power from the constant power wire (Green with purple stripe) wire. I assume that I may have blown a fuse when I removed the radio. I checked the radio fuse in the interior fuse box and it is good, but I think that that is for the ACC power. Anyone know where the constant power source is. Before I start splicing wires (which I do not want to do) to get the green/purple wire hot, I want to see if it is an easy fix. Thanks in advance for any assistance. 1995 XLT with premier radio AM/FM/cassette with factory amp.
