- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
My 1995 ranger with a 4.0 seems to have an intermittent rough idle. It will barely idle in this condition, 400-600 RPM, sometimes stalling.
It usually happens when warm. Sometimes/often snapping the throttle seems to help.
I did recently swap IACs with one out of a 3.0 (my old ranger) which upon writing this post might be suspect (I had another spare one I swapped for this one awhile back after suspecting a different issue). I bought the truck a month ago and it was sometimes idling way too high, and I found a dead spot in the existing IAC. Being lazy, I grabbed this IAC out of my spare pile rather than pulling from the dead truck. I still have the wrecked remains of the old ranger (not yet sold for scrap), so maybe I should pull the IAC off of that and swap again?
That is assuming that the 3.0 IAC is compatible; it looked a bit different but the connectors, bolt holes, and mating surfaces all matched up. After the first swap, my idle hasn't ever gone that high (2000RPM) but still runs a bit high when not rough (1000-1200RPM)
I did clean the MAF with MAF cleaner and the throttle body with throttle cleaner (the later was quite dirty), but to no avial.
Another thing I've noticed tonight was something odd with the downstream O2 sensor. Just for my information I was plotting the 02 sensor voltages using Torque Pro, and it seems that while the upstream sensors are behaving as expected (switching between .2 and .9 volts), the down stream isn't switching at all. It was reading dead 0 at a somewhat warm idle, but after driving it was fluctuating between .7 and .2 volts, but very slowly (unlike the upstream sensors). Since it's the downstream sensor, I doubt that's the cause of my rough idle, but could that indicate a separate issue?
Any advice on either issue? If nothing else this weekend I will try swapping IACs with a known good one (assuming that using a 3.0 IAC isn't actually an issue).
