qorray
- Jan 9, 2022
- Fort Worth
- 4.0 V6
- Automatic
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 225/60/15
- My credo
- ODAAT
I have a set of 95-97 Ford Ranger 4.0 cylinder heads for sale. Great overall condition on parts. These came off a 1997 Ford Ranger 4.0 AT, 121,000 on motor. One head is good, one is cracked. These are OEM Ford heads part # 95TM6090AD, these are harder to find because the years these were used is narrower. I also think these will fit others years but unsure exactly of what can be swapped, Ranger Station is full of information on what works and what doesn't. I bought new ones so passing these on.
Heads were gone through at HNH Machine Shop in Haltom City Texas, I can give you the name of the guy who worked on them for reference. These were magna fluxed also and a crack was found in one head. The picture with the "x" on the bottom of the head is the one that is cracked, can be pinned if needed but only by someone skilled enough to do that kinda work. The other head is totally rebuildable. I'm including both heads, spring, valves, keepers, a new set of Fel-Pro valve seals part #SS72686 and a set of exhaust manifold gaskets. Everything is here to make one good head if you have a Ranger.
I live in Fort Worth Tx, these would need to be picked up. $75.00 for all, really good deal. Thanks
