So I’ve had some trouble with my steering since I got the truck. It had a ton of play and made some noise.
At first I thought it was the rag joint, replaced that and it got better
Then I thought it was all the linkage and tierods, replaced that and it got better
Then I replaced the steering wheel with an after market unit, not so much to help the steering but to have a smaller nicer wheel. The aftermarket hub was trash, but I fixed that with a better one that fits tight
Then I thought it was alignment, had that dialed and it did get better
Now I have no play in the steering, but I still have a terrible chirping/squeaking sound coming from behind the wheel when I turn the wheel. I think it’s actually coming from the bearing/bushing that the steering column rides on. I found replacement/upgrade, but I’m trying to figure out how hard it is? How common it is? Or if there’s something else likely causing this.
