1994 Axle flip ext. cab
Zmans
Forum Member
Delaware
2.3 (4 Cylinder)
Dropped rear 5 converted to single shaft.
clearance issues with cab/tunnel. Driveshaft
rubs .
  • 1994 Axle flip ext. cab
What is the driveline rubbing on? Tunnel of the rear of the cab? How did you flip the axle? Did you use spring relocators for the bottom of the axle?
I used the axle flip bracket which has a relocation hole that is aimed towards the front offset location. Spring is relocated under the axle. The driveshaft is rubbing under the rear of the cab, I recently swapped the 2 piece over to the aluminum 1 piece from a 99 ext cab 2wd 5 spd ranger.
I am running into the same issue right now, I will come back to you if I figure it out!!
Interesting. I used an Explorer 8.8 as spring under with a one piece steel shaft on my green 00 Ranger and the only thing the shaft rubs on is my muffler
