1994 2.3 crank sprocket, other compatible years?
kp3ft
The saga continues with my crankshaft sprocket removal woes. I ended up getting it off by grinding and drilling it off, after trying everything else, so now I need to replace it. I found one for sale on the internet that says it is for 1995-1997, but it also says it may fit other years. Does anyone know if it will fit a 1994? Mine is a round tooth sprocket, and the one on the internet is also. I did search the internet for info, but for some reason even finding these sprockets for sale at a reasonable price is very difficult, let alone finding compatibility info. Thanks
Jeff
crankshaft sprocket? the balancer?
It's part of the whole timing gear set, a small gear behind the balancer. This is a picture off the internet from a different year 2.3 Ford motor; it's a square tooth sprocket, but the same setup as mine.
as long as it's for a round tooth belt it'll work.
