1992 seat tracks
VAMP_15
5+ Year Member
What other years have the same seat tracks (brackets) ?
My Neighbor's 92 ranger doesn't slide or lock in...
I believe any regular cab brackets from 84-97 should swap and if the truck is an extended cab, all extended cab brackets will swap.
Thanks
Thanks Burls.. it is an ext cab..
( 4.0 v6, auto,4wd)
89-92 extended cab rails will swap in for sure (there was a change-up in 93 putting an extra hump in the floor. You can extract a hump from a 93 onward and weld it in if you want to mount newer seats - apparently up to 97 anyway - I did this on my 91)
Pretty sure 88 and older extended cab rails will work, too, if you can find them in decent shape. But def 89-92.
