1991 Aerostar 4.0l into a 1989 Bronco II. What can I use from the aero?
Iowa
Hi,
I'm considering grabbing a 600$ 1991 Aerostar with the 4.0l and the AWD system. So I can take the 4.0l, rebuild it and put it in my bronco 2 with a busted 2.9l
Both are automatics, but the bronco is a column shifter and the Aerostar has a floor shifter. My question is what can I use of the Aerostar in terms of the engine swap.
Harness, ECM, do I need to replace the dash? I see a lot of info about swapping from a ranger to a bronco or an explorer to a bronco, but very little on the Aerostar expect that it can be done and the exhaust manifolds are different.
Thanks
Engine is the same as a Ranger/Explorer 4.0, not sure if the exhaust manifolds are the same but I'd be a bit surprised if they were not. Transmission is the same thing, both A4LD's. Compare them, there were small changes made to wiring connectors and stuff over the years but 89 and 91 should be very close if not identical.
You will need the engine harness & ECM at a minimum. I don't know how the Aerostar harness compares to a Ranger or Explorer. I did a 4.0 swap on an 89 Ranger years ago - 94 Explorer was my donor - and I had to use the dash harness as well for some reason. Might have just been easier because the big cannon plug matched and I didn't have to re-pin it. *IF* the Aerostar has that big cannon plug and *IF* if plugs into the B2 dash harness, I would just verify that all the wires go where they need to go/re-pin as needed and use the dash harness & cluster that you have now.
Aerostars as a donor are totally viable for 4.0 swaps, just hasn't been done very often so you are in somewhat uncharted waters.
Exhaust manifolds were different on my Aerostar junkyard engine.
I have doubts that any two 4.0 harnesses were actually the same from 90-94. LOL Even though they support the same engines and PCMs, the connector shapes or routing are different. (Is the Aerostar PCM in the passenger kick panel?)
You know, trying to go through my 4.0 swap and try to remedy some issues it’s had since I put it together, I bought EVTMs for the 91 Ranger I believed the harness was from and an 89 Ranger/BroncoII. When wire colors and stuff started not always matching, I bought the 90 and 92 Ranger EVTMs. When those didn’t help I got a 92 Explorer EVTM. I still have wire colors that don’t match any of them… thanks Ford… :temper: :temper:
If I was still racing my ranger I'd want the t-case.
Well, look at the bright side . . . at least you have some great bathroom reading material.
I also have an 88 Ranger/Bronco II book, 89 F-series book, and a 98 Explorer book…
