1990 ford ranger a4ld
dgeist57
When in drive the transmission shifts perfectly. Reverse is good. But when you try to start out in the overdrive position the tranny acts as though it is slipping' I need help! I have cleaned the governor and valve body well, changed the servos that are accessible from the outside of the tranny. This is all after I completely rebuilt the unit. It shifts so smoothly from the drive position it is almost scarey, but from the OD position nothing. Any suggestion would be greatly appreciated.
Thanks, dgeist:yahoo:
Sounds like the OD sprag has failed.
