- Aug 22, 2017
- Automatic
So ive been dealing with this sputtering issue for awhile now. Ive done the following already:
Replaced all Spark Plugs.
Replaced all Spark Plug wires.
Replaced Distributor Cap.
Verified Firing order is correct.
Replaced Coil Pack.
Replaced ECT.
Replaced Thermostat.
Replaced Thermostat Sensor.
Replaced IAC valve.
Replaced IAT Sensor.
Replaced Air Filter.
Replaced Fuel Filter.
Replaced TPS also adjusted.
Cleaned Throttle body and replaced gaskets.
Today I replaced all 6 fuel injectors and now the truck seems to be doing even worse. There are no leaks from injectors or FPR. Battery was unplugged for 30 seconds to reset ECM. Only codes I get are 10 and 11.
Help?
Replaced Coil Pack.
Replaced ECT.
Replaced IAC valve.
Help?
