chatham
- Nov 10, 2011
- Automatic
have a 1990 BII with 2.9. got up one morning and wouldnt start. would turn over but would not fire. chased down what i think caused the problem. bad connection at the fuel pump. changed the filter for good measure. clean the corrosion out and fuel pump began pumping just fine. now however when i try to start it fires right up and then dies immediately. this happen every time.
i have searched all the forums iincluding this one and havent found much on this problem. i have a haynes manual which is pretty basic. first time for me working on a BII.
for the life of me i cant find the fuel pressure regulator and where the fuel comes into the motor.
is this an issue with running the fuel injectors dry?
thanks for any and all advise
