Will check compression this weekend.Id check compression next..just to rule that out.
Yeah thats extremely high.Compression looks like this...
212.0, 186.0, 193.5, 186.5, 199.0, 193.0
Seems high, perhaps we did something wrong. Used Mighty Vac Digital Compression Tester MV5532. High is ok? Low is bad?
Disconnect while checking compression? We have replaced the MAP sensor, it wouldn't run with the old one in. Swapped it out for a new one and the truck now runs.disconnect the map sensor
