Ceej
- Mar 29, 2020
In the two areas where you see the copper trace, there was damaged coating. where the break is, it was completely covered in burnt coating. The trace was burnt in two, and the ends curled up. Unless the component completely burned up, there was nothing there. The photo is after cleaning the surfaces. I just ordered a loaded ECM, as without a schematic, it will be very difficult to troubleshoot the board. This appears to be tied to a common trace leading to several devices across the board, one of which is a small SMD populated daughter board of six conductors soldered at an angle off the motherboard. There is an 8pin SMD on the daughter board along with other components. My electronics background is a bit aged, so I've not been able to identify what many of the SMD's are. They don't seem to follow the tables I find online, as the numbering scheme doesn't match up, (Where I can read them.) I can tell which are caps, diodes and resistors, but some of the other surface mount parts are outside my experience. It's no longer worth the time to fiddle with it. Thanks for trying to help!
CJ
CJ
