- Oct 3, 2022
- Chauncey, OH
- 2.9 V6
No, I haven't. The local transmission shop couldn't find one either. if you remove the coupler, the bolt holes line up between the trannie and drive shaft. Putting a piece of thick rubber between the two and bolting them together may work although I haven't tried it. The rubber would allow just a tad bit of flex as needed. Probably need lock nuts on the bolts. I am still driving on the original coupler, but it is definitely time to do something about it. Thanks for the reminder!By any chance did you succeed in finding one? I have a 1989 Ford ranger that has a coupler that is cracked and I'd like to replace it. What did you end up doing? Thanks!
