Found the issue, waiting to resolve...
Oh, you wanna know what it is?
Clutch is slipping
Well if the clutch isnt releasing the motor overheats
We highlighted the mark on the balancer for TDC and also at 10*. Then we pulled the black "pill" as everyone calls it that is basically a shorting bar on the 2 wire connector that is over the passenger side valve cover, about 6" from firewall. when we checked it at first it was like 14, then when the truck idled it moved to 20. we set it to 10 and put the pill back in and checked it and it looks like it held.
I appreciate your help Kyle...
My thoughts from here...
A) Truck still has a computer for the automatic transmission, but the computer is not getting signal from the manual transmission because the only plug that is actually plugged into the tranny is the reverse lights.
B) Truck has sat for a long time, I have replaced fuel filter but I heard there is a filter inside the fuel pump under the drivers seat on the frame. That or the in tank fuel pump may be bad and the frame pump is the only one running.
