Not easily. I used to drill into the lock cylinder, screw a slide hammer in and beat the cylinder out, then install a new cylinder. Three things to count on: the sun will come up tomorrow, we'll all die someday, and salesmen can't keep track of keys.
If there was an easy way to remove the ignition cylinder with no key there wouldn't be much point to having one in the first place.
Drill it... sometimes on an older truck the tumblers are so worn you can just use another similar key and jiggle it enough to get it to turn.
Or you can remove the door lock cylinder (no key required) take that to a locksmith and have them make a new key. This of course only works if the door and ignition use the same key.
Yes, your removing the tumblers which are what hold the cylinder from turning. Once the core containing the tumblers is out your good to go and can just remove the remaining part and install a new ignition.
This won't work before the late 90s as the door and ignition locks were different and the two keys can't even be interchanged because the blanks are different. The blade off-sets are reversed so the door key doesn't go into the ignition and vice versa.
1991ish was the first year of one key - my 1992 Explorer has one key for the locks and ignition. It has a second key that only works on the glove box, though. Had several other trucks that are like that too. 1988 would have had a separate ignition key regardless.
Good luck, it's a pain no matter what... Sometimes you can use channel locks to break off the wings on the lock cylinder, then hammer a flat screwdriver in while turning the screwdriver. That can make them turn so that you can stick a punch in the release hole and remove the whole lock cylinder. It does not work every time.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
