mihulka3
- Nov 17, 2009
- Automatic
Is it just me or do others have vibration issues on extended cab Ranges?
I've had the driveshaft worked three different times and pulled the transmission during engine swap to check it. I've checked the differential as well. I've come to the conclusion it's in the transmission. The unit shifts okay but from about 40-60mph it has a noticeable vibration. Is it the overdrive?
