- Nov 25, 2024
- Age
- 74
- 2.3 (4 Cylinder)
- Manual
- My credo
- Semper Paradus
Hi All,
I'm a novice and trying to get my 1987 Ranger 2.3L, Manuel Trans. running. This truck was setting for 18 years. Below are all the things I've done so far.
Replaced both Fuel Pumps and cleaned Fuel Tank.
Replaced Spark Plugs
Replaced Fuel Injectors
Replaced Distributer Cap, Rotor and Plug Wires
Replaced Clutch Master and Slave Cylinders
Replaced Battery
Replaced Timing Belt and set timing marks with cam and crank and #1 cylinder at compression TDC with rotor set at #1 plug. Firing order 1,3,4,2.
The truck has only 120,000 miles on it.
Compression is 180 in every cylinder. Bore Scoped all Cylinders, they are in great shape. Pulled valve cover and the cam and valve train all looks to be in great shape. Checked all vacuum lines.
Fuel Pressure is 40 psi, Fuel rail is clean and gas flows. Can hear Injectors click.
Have good spark at Coil and all Plugs. Wiring all looks good.
Engine cranks good with no bad noises. Engine will fire on starting fluid and tries to fire on gas but will not run.
I'm running out of ideas. Could it be a bad computer, the Ignition Module or are there some sensors that could keep it from running?
Can only test for codes with ignition on and not running - no codes.
Any suggestions or testing ideas would be greatly appreciated.
Replaced Battery
