- Aug 15, 2007
- 2.3 (4 Cylinder)
- My credo
- vertical and above ground
Have you checked the time it takes for fuel pressure to bleed down? Three or four things can cause quick drop. Leaky or stuck injector(s), bad check valve in the pump, bad check/anti-bleed down valve in the regulator{return line check valve} or leaky fuel line.
A stuck injector [rare] would allow too much fuel, and the computer would try to lean it out, cutting all injector time pulse, but having no effect on the bad one. Fuel pressure would drop in the line as soon as power was removed from the pump. You can remove the injectors as an assembly [see recent post about that]. enable the pump, and check for drool or drip. You can crimp the return line[NOT RECOMMENDED - PERMANENT DAMAGE can result] or plug it, and so on.
You can also check the Hz reading from the MAP sensor and compare its result to a table of values for given altitude / baro pressure[non-running value, key ON]
tom
tom
