00srad600
Ok so first off about the truck it's an 88 super with 2.9 5 speed 4x4. The truck in a week or so will be up on 36 inch tires running 4.88 rear ends. Now onto the motor it been ported heads lower and upper intakes running a 85 tb. The sparks are MSD coil and distbutor with 8mm wires and hotter plugs running 14 degrees advance on 92 gas. K&N filter and high flow cats and thrush 3 inch inlet duel 2.5 out right before the tire. Would the 19 lb injectors be money better spent on headers
