15x10" rims Help!
Falcon4x4
Grand Rapids, Mi
Im looking to get some new rims for my 04 Ranger xlt, but im unsure if the 15" rim will fit, The stock size is 16x7. Im gonna do a body lift and im looking to run 33" tires but but ive ony seen rims with 10" wide on 15". Like the Cragars D window. if you have any info or picture anything helps, Thanks
33x12.5x15 will do best with 8 inch rims. This is what I run on my 99 Ranger. If you go with a wider 33 then go the 10 inch route and it will also look great.
Here is a photo of mine with the AR rims (15x8) on 33x12.5 KO tires.
i run a 33x12.50r15 on 10 inch wide rims, i air down to 4 psi at times in the snow and have never had a problem. i honestly think it depends on the rim of how well it holds the bead. we have a friend with 8 inch rims that airs down to 10 psi and blows the bead all the time.
